Busted AC in 100+ degree heat!
Old 07-08-2008, 12:37 AM
srahimi
srahimi's Avatar
Default Busted AC in 100+ degree heat!
Hey guys,
So I know that my AC needs more than just a charge. When I turn it on it doesn't blow cold and my RPMs jump up and down in a constant rhythm. I called Ford and they said they would tell me what the problem was for $125 bucks. Dealership, go figure. Any ideas guys? I would appreciate any help.
srahimi is offline
Old 07-08-2008, 12:43 AM
black35th
black35th's Avatar
Default RE: Busted AC in 100+ degree heat!
Start the car, pop the hood, turn the A/C on MAX. Look at your compressor to see if its running, its gonna be on the right side of the motor at the bottom.
My guess is that it just needs a charge, the RPM's jumping is due to your compressor kicking on and off because it needs to be charged. You can charge it yourself, its real easy, they sell a kit at your local auto parts store for pretty cheap.
black35th is offline
Old 07-08-2008, 01:01 AM
srahimi
srahimi's Avatar
Thanks for the advice. I'm not sure if I can get an AC recharge kit locally. I'm not sure where you are located but in California not many places recharge your AC anymore because shops need to have some sort of license to carry it now. I may be able to order online though.
srahimi is offline
Old 07-08-2008, 01:13 AM
black35th
black35th's Avatar
Wow, I wasnt aware of that. The last time I checked it was the standard R-134A that was used to recharge A/C's. But I'm in Ohio and I know you guys have some pretty stiff emmision laws and stuff out there so it wouldnt really suprise me.
Good luck though man.
Old 07-08-2008, 07:29 AM
Sxynerd
Sxynerd's Avatar
ORIGINAL: srahimi
You can buy R-134 in califorina.
Sxynerd is offline
Old 07-09-2008, 10:03 AM
99bgt
99bgt's Avatar
just buy the fake stuff at autozone or kragen or pepboys it worked for me and it was easy
99bgt is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Busted AC in 100+ degree heat!
