noob head question
Old 07-08-2008, 05:46 PM
sultan68
sultan68's Avatar
Default noob head question
i heard that the 99-04s had 3v heads is this true? I tried searching but it came up with nothing..
sultan68 is offline
Old 07-08-2008, 05:54 PM
Houghtown
Houghtown's Avatar
Default RE: noob head question
3-valve
[/align]4.6L 3-valve SOHC V8 installed in a 2006 Ford Mustang GT[/align][/align][/align]The 3-valve SOHC 4.6L with variable camshaft timing (VCT) first appeared in the redesigned 2005 Ford Mustang.
The engines are equipped with an electronic Charge Motion Control Valve (CMCV) system that provides increased charge motion at low engine speeds for improved emissions and low-rpm torque. Cylinder block material varies between aluminum used in the 2005+ Mustang GT and cast iron used in the 2006+ Ford Explorer and the 2007+ Ford Explorer Sport Trac (see below), though the same aluminum heads are used in all applications.
The 3-valve SOHC 4.6L engine was on the Ward's 10 Best Engines list for 2005–2008.
Vehicles equipped with the 4.6 L 24-valve SOHC include the following:
[ul][*]2005–present Ford Mustang, 4.6L, 300hp (224kW) and 320ft·lbf (434N·m)[*]2006–present Ford Explorer, 4.6L, 292hp (218kW) and 300ft·lbf (407N·m)[*]2007–present Ford Explorer Sport Trac, 4.6L, 292hp (218kW) and 300ft·lbf (407N·m)[*]2009 Ford F-Series, 4.6L, 292horsepower (218kW) and 320lb·ft (434N·m) [/ul]
That came from Wikipedia. As far as I can tell those are the only 3 valve heads that they made.
Houghtown is offline
Old 07-08-2008, 05:56 PM
black35th
black35th's Avatar
LOL no they have 2v SOHC heads. 05+ Mustangs have the 4.6 3v, and Cobras/Mach 1's have a DOHC 4.6 4v.
black35th is offline
Old 07-08-2008, 05:57 PM
jrherald420
jrherald420's Avatar
thats a big no
jrherald420 is offline
Old 07-08-2008, 06:00 PM
sultan68
sultan68's Avatar
alright, thanks for the help guys
sultan68 is offline
Old 07-08-2008, 07:06 PM
foursixblurrrr03
foursixblurrrr03's Avatar
but the good news is that the GT's from those years have the PI heads
foursixblurrrr03 is offline
Old 07-08-2008, 08:17 PM
boduke0220
boduke0220's Avatar
wouldnt that be sweet if all the heads were interchangeable ( huge word for me)...that'd make my day and year
boduke0220 is offline
EASTIDEE123
09-14-2015 03:52 PM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: noob head question
