Cutting my coils to drop the stang
RE: Cutting my coils to drop the stang
so if i go with the sportline kit, i just need a bumpsteer kit as well and i should beall set.as i already have aftermarket CC Plates. Is this correct redstanger? With the steeda kit i have now lowered about 1.25" their is no bumpsteer kit, i talked to the family friend and mechanic i bought it from and he said he just installed struts, shocks, and the steeda kit along with the CC Plates and thats it and everything is perfectly fine.
ORIGINAL: redstanger
johnr2001gt
you lower'd your car and didnt have caster camber plates? 2inches. na your full of s hit its running out your ears. your tires have got the top angled in. I did mine an inch and factory camber caster plates can only handle an inch of drop. mine was still off after i got alignment done because the factory ones can only move toward the fender so much.if you want to hibilly stuff do it. If you want to do it the right way/professional way to MAKE SURE the alignment is right and the geometry of the front suspension is right do what i told you.
johnr2001gt
I also said each case is different on my sons 98 we dropped it 1.5" and had to put caster and camber plates on it to correct the negative camber. so run that out your ears and grow the f- up
ORIGINAL: 96GTMustangCT
johnr did you cut your springs or was this with a kit?
http://i269.photobucket.com/albums/j...t/DSC00022.jpg
ORIGINAL: bb816331
Is a TERRIBLE idea! It's unsafe, and if done incorrectly can really affect the car. Do it the smart way, unless you want to spend more money down the road. Keep in mind cutting them weakens them. Plus, i doubt you could cut each spring 100% equal.
Note this is stock springs I'm talking about. It doesn't effect them since they aren't progressive rate springs.
Stop listening to all the hearsay bull**** and get some real facts.
ORIGINAL: Xemeth
Wrong. Cutting springs is completely fine. Cutting them does NOT weaken them at all. Also, as long as they are almost exactly the same, the car will sit even. It's not that hard to do.
ORIGINAL: bb816331
ORIGINAL: steve0914
doesn't the op have progressive springs and isn't talking about cutting his stock ones...cutting the stock ones are fine, but it is a bad idea to cut aftermarket progressive springs
ORIGINAL: Xemeth
ORIGINAL: bb816331
whats up everyone. i appreciate all the help. i think the route im gonna go is get the eibach sportline. hopefully that will sit low enough. i think im gonna leave the struts and shocks alone as they are in fine shape and were changes when the steeda spring kit was put on. I have CC Plates. My only question left is, do i need a bumpsteer kit, and how bad of an idea is it to leave the struts and shocks that are on it now?? they are tokicos
your shocks and struts will be fine may just not last as long as they should. if you go 2" on the drop later on down the road just put some shorter ones on. good luck in which ever route you take.
