nitrous
#44
RE: nitrous
whats this only use the stock fuel pump if your not gonna run it often stuff. car parts dont have time limits they either work or they dont. i ran a 100 shot on the stock fuel pump and had no problems but it was on my list of things to get just for piece of mind.
#46
RE: nitrous
you will be fine running up to a 125 shot i talked to the techs over at zex. But it was also for a wet shot ive heard you can only go up to a 125 shot on a dry shot. I dont reccomend running dry b/c i have had my fuel pump go out while running the gas. I recomend if you go dry get a switch to shut it down if your fuel pressure goes down. Another thing would be if you go over 125 or more ur going to be taxing ur pump.
