breakin gears?
breakin gears?
i hear you should heat cycle your gears or breakin period of 500miles. i just had my 3.73 installed on my 2002 and i punched 4th on interstate after about 60 miles on the new gears. anybody think this may cause problems down the line? im going to change gear oil after about 1500 miles or so.
RE: breakin gears?
you should be ok. you should really let the gears go through a few heat cycles to let the seals seat. such as drive it for a half hour let it cool for at least half a hour. do that like 3 or 4 times and then you should be good to go. thats how i did it at least.
RE: breakin gears?
ok thanks, after i gothome i did the heat cycle thing. i havent even spuntires in first yet. so who herestarts in second gear everytime now with 3.73s? seems alot smoother to me and i wont get burnt off the line when im not racing.
RE: breakin gears?
ORIGINAL: highroller02
and about breaking in the gears...when i got mine installed they said i could start getting down on it after about 30 minutes of driving
RE: breakin gears?
When i had mine put it in. They drove around with me to check for any noise. There was no noise and he said that was the heat cycle. We let it cool down and then he told drive it how you normally drive it. Mines been fine since. I still took it easy for a good 200-400 miles though getting on it a couple times.
RE: breakin gears?
iv said it before..and ill say it again. i left sideways from my install and have had 0 problems since..
the reason they tell u to break em in is so it covers the installers *** if theres a problem. when u go test drive a new car, do u not beat the hell out if it with wat 10 miles on the car? do you hear any gear noise NO...do you know why? cause they where installed correctly.
RE: breakin gears?
sweet, thanks for all the responses and im sure they were installed correctly! So starting in second gear with 3.73s doesnt really put any more stress on the transmission? im not launching the car from second gear. atleast i havent tried it yet
