Rear Wheel Squeek
Rear Wheel Squeek
I've been hearing a noise from my right rear wheel. I noticed it does this when I make a right turn. It doesn't matter if the brakes are on or off. Any ideas what this could be?
RE: Rear Wheel Squeek
if its the diff, jack one side of your car up leaving one rear wheel on the ground and try to turn the wheel thats in the air if it turns fairly easy the diff clutches are shot. if it take alot of force to turn there fine.
ORIGINAL: jrherald420
there should be alot of resistance when trying this with a good diff. as for trying the other side i dont think it would help. one other for sure way is go smoke the tires you will have 2 black marks if its good and 1 if its bad. check this out it will give you a better idea on whats inside
http://www.mustang50magazine.com/tec...ild/index.html
my diff clutchs are shot right now and are making a rubbing/ grinding/squeaking noise and have been for a year!!!! it started as a squeaking noise and turnedinto the rest. so dont tell me that it cant make noise!!!!! ihave a new diff waiting to be installed because of this noise that cant happen!!!!
im not saying that it cant be a bent axle, it might be!!!! i wouldnt be able to tell unless i was there looking at it. i was just giving him adiffrent road to try! and sharing my personal experance on this subject.
