steeda suspension
#21
RE: steeda suspension
ok so i heard that the carpet in the car can burn if u weld in subframe connectors i want to know if this is true becuase if it is then i will not be getting weld in subframe connectors
#23
I welded my subframe connectors in without any problems, if you are using a MIG or a TIG you shouldnt have any problems, the only way you might burn the carpet is to use an oxy-ace torch and suck at welding.
Matt's 95 Stang
10-05-2015 07:16 AM
09-24-2015 09:18 PM
