What do u think about cams
RE: What do u think about cams
Well, l looked at their website and again I am not impressed, and here is my reason why. All the camshafts for 2v stangs are reverse split. This type of cam shaft is good for a car with stock heads. You should also have a good to excellent flowing exhaust. It appears that you have chosen their STAGE 2 cam. Let’s take a look and see if you made the best choice for your application. The first thing that stands out is that you have 100 NX. This is the worst type of camshaft for NX.IMO Like we said before reverse is good for stock heads (poor flowing intake). When using NX you do not have a problem getting air into the motor, but getting it out. So why would you want the intake duration to be longer then the exhaust. In this case you could a chosen a traditional split cam which means the intake duration is smaller then the exhaust duration. Even a single split camshaft would have been better choice just advancing it a little more, so the exhaust events happen sooner. (this help to reduce pumping lose) When someone is using NX just for fun I will usually spec a N/A cam. If they want max performance on NX. Then I spec them a nitrous cam which usually cost them about 15rwhp when compared to a N/A cam. However, when on NX the nitrous cam will out perform the N/A cam by about 25-50rwhp. It all depends on the shot of NX. I am not trying to be a d!ck. I just want people to make a better choice when selecting a camshaft for the vehicle. I wish people would stop referring to cams by stages and say the cam spec. It would help people on the forum to understand how different bolt on and camshafts effect the torque curve for a vehicle. The best learning tool would be the dyno sheets and R&D. I hope to see more of that here on the forum. In the end as long a you are happy with your vehicle that’s all that matters. One last thing, do you know anyone that can sell me a STAGE 12 cam.jk Good luck with your horse power goals.
ORIGINAL: defconfire
They peak around 5750.
I love the cams in my car(vt stage 1) They are great for daily driving, which I don't do much of anyway(ride a bicycle everywhere). I did the install myself because I had the motor out of the car and heads off. With my mods in sig and the cams with a tune from Big Daddy Performance, I got 292 hp at the wheels and 316 ft lbs of torque. I got the dyno sheet floating around somewhere on the forums. I would probably be over 300 if i had some long tubes on it but i gotta watch emissons.
First post has the dyno sheet just click the box
My dyno post
Replacing the intake manifold on our cars when they are NA is basically a waste unless its like Code's old 01 GT that was worked beyond belief. If you plan on running a shot of nitrous, it would be worth it to swap the manifold to something elsefor the extra gain. If you comtemplating replacing the heads with something ported a little, then replace the cams while your in there to take advantage of extra air.
Hope that helps some
My dyno post
