I've got a 2000 GT. A/C comp. stopped working a few weeks ago, not good in South Florida. Checked fuses, checked A/C temp sensor, ran power direct to comp. and it cycled. Changed out CCRM still have same problem. I pulled the Batt. cable to reset the comp. it cycled for a few seconds then stopped. Did it again same thing...... What the hell is going on.
if the compressor isnt running how can youtell if the pressures are correct? you may have a pressure sensor problem, a wiring issue, or a clutch air gap that is out of spec
