Gas Pedal is all jacked up
#21
RE: Gas Pedal is all jacked up
You are correct about the plate opening fully being the "stop".
MachWon04, you will never break the throttle cable with your foot. That is a steel braided cable and can take alot of tension. The creaking noise you probably heard was your ghetto spacer.
#22
Alright cool Did not think to realize it was likely the spacer. I was most worried about the end popping off the cable but if no one else has broken anything, I'm doing it.
#24
i tried the mod last night with a black rubber hose and zip ties but i didnt want to put faith into it. wen i would press the gas pedali could see the hose flexing and "bunching" up and i was going to use hose clamps but i couldnt get the damn things to tighten enough.
so today im on a search for a little bit stronger hose and better hose clamps any suggestions
#25
i didnt use a hose at all.....just stacked a few zip ties....they have been working fine....they've been on for months with no problems at all..
i've heard of people using all kinds of things for the "hose"...like a little piece of an ink pen...stuff like that.
maybe someone else (that didnt use zip ties) can/will chime in and explain what they used.
#26
ORIGINAL: black35th
LOL I broke a clutch cable with my foot.(it takes skill) Which sucked. I had to drive home without stopping and shifted all the way home without the clutch
#27
ORIGINAL: cassimus
From what i've seen the most efficient way is like whatmoko said and to use either "stacked" zip ties or take apart a plastic bic pen and cut it to size. Usually that wont slip either.
