Piggyback UDP's
Old 07-18-2008, 02:27 AM
Novanutcase
Novanutcase's Avatar
Default Piggyback UDP's
Can someone tell me what the pros and cons are to piggyback UDP's versus, say, Steeda UDP's? I'm thinking of getting these:
John
Novanutcase is offline
Old 07-18-2008, 03:51 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Default RE: Piggyback UDP's
There are no pros, unless you consider their being cheaper to be a "pro". [/align][/align]The crankpulleyis even more hassle to install than a proper pulley.[/align][/align]The cons are that they cantilever mount the harmonic dampener quite a bit further forward than it was designed to be, and use surfaces of the OEM crank pulley for alignmentwith the new pulley that were never intended or machined to be used for alignment with anything.[/align][/align]Thisoften causes the OEM pulley/dampener to wobble a bit; introducing vibration, which is never good.[/align][/align]They also look like crap, like some sort of jury rigged setup someone came up with because they were too cheap or unskilled to do it right...[/align][/align]Other than that they're fine...[/align]
cliffyk is offline
Old 07-18-2008, 03:59 AM
Novanutcase
So you're OK with it other than that.........LOL!
Fine, I'll get the Steeda pulleys!
How are the Motoblues?
John
Old 07-18-2008, 04:05 PM
20GT02
20GT02's Avatar
Search "Mustang Underdrive pulley" on youtube. I found a pretty interesting, detailed installation process for Steeda's and some cons of using piggybacks versus Steedas crank/dampener.
20GT02 is offline
Old 07-18-2008, 10:47 PM
POISND U
POISND U's Avatar
Everything you need to know about piggybacks:
Don't buy them. Get Steedas.
POISND U is offline
Old 07-18-2008, 10:58 PM
steve0914
steve0914's Avatar
what is a piggy back system? i never understood that... i just bought steedas, but how can you tell the difference?
steve0914 is offline
Old 07-19-2008, 02:50 AM
POISND U
POISND U's Avatar
ORIGINAL: steve0914
You didn't read Cliffy's post, did you?
POISND U is offline
ghoste
06-22-2005 06:46 PM
Obselite
06-16-2005 09:33 PM
Obselite
06-14-2005 08:33 PM
Dan04COBRA
18
05-09-2005 10:48 PM
Quick Reply: Piggyback UDP's
