Ugly PUlley Squeal
2010 Blue Ball Award Recipient
Ugly PUlley Squeal
It's not the tensioner pulley, and it's not the idler pulley either.
I bought a new pulley and tried replacing each of them, and both times it still squealed.
Could the air conditioning compressor be making the noise, or maybe the alternator?
It sounds JUST like when I had a bad bearing in the tensioner pulley and replaced it last spring, but now it's at it again, but it's not either of the aforementioned pulleys.
RE: Ugly PUlley Squeal
Idler pulleys have been known to squeek on the earlier models (NPI) usually when cold. While the engine is running use a flathead screwdriver and hold in with slight pressure on the belt. Make sure the squeek is coming from there. If it is, the squeek should stop when holding pressure on the side of the belt. After that you're going to have to listen real close or remove the belt and hand spin each pulley. Did you spill coolant on your belt when doing the work? Sometimes that'll make them squeek for a while.
ORIGINAL: bt1288
Mine did the same thing and it turned out to be th alternator.
im not sure if its a puly, o if this gu[y said it miht be the whole alternator?
its crazy, loud al the time, nmot just w hen i star tit
ORIGINAL: Modular_Madness96
its a bearring in your alternator rebuild or replace the alternator
I swear it sounds JUST like the tensioner pulley I replaced last spring, or the fall before that.
However I know that's not it since I changed out both pulleys that I thought it was.
ccdguy
09-19-2015 05:20 PM
