Engine stutter please help!!!!
#22
RE: Engine stutter please help!!!!
my car only threw the cat code but the underlying problem was just a loose plug and a few odd ball plugs from the dumbass before me but the shop scanner can eliminate a lot of controversy and at least tell you where your problems are or where to start looking
#23
Pull the COP's and clean the coiled up wire on them in the boot. Then pull the plugs and replace or clean them up real good. If i am correct it will be the 2 nearest the firewall on each side. Use a wire brush to clean the wire.
The same thing happened to me and it took me about 3 weeks to figure it out, the rubber boot on the valve cover does not keep all water out and it seeps into the plug hole. If i am correct it will look like a bunch of sludge in those 2 plug holes. try not to knock anything down into the plug hole though.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
