What do power pipes do for fi
im about to buy a procharger stage 2 kit and i want to run 10lbs ive heard power pipes increase this and i am gettin the kit from anderson ford motorsport and it comes with a power pipe so should i get a 8lb pulley and the power pipe will take it to 10lbs. That is what ive heard from ppl
RE: What do power pipes do for fi
any info?
Increase volumetric efficiency allowing for more air to flow into the s/c. Thereby having more air in the system, more air in the system increases pressure because of the restriction, which is measured in lbs of boost. And, on an increasing scale, as the pressure builds, the higher RPM's will have more boost. So, you have more boost with the same pulley equally more HP.
I tried sounding smart.... Someone smarter than me will chime in soon, i'm sure. |
Hey, let me try to sound smart. You put the bigger pipe on der and it makes bout a lb more boost. How'd I do?https://mustangforums.com/micons/m16.gif
Groovy Baby!
