Everyone, read this please! I want REAL opinions!
Okay, I am bringing my car to the Ford Dealership tomorrow to finally get every single freakin problem that my car has fixed ONCE and for all.
1. Clutch will squeak when fully released (moving or standing still) and "tick" when fully depressed (only when moving)
2. When coming to a 5mph-0mph controlled stop, the brake pedal vibrates. I removed ABS fuse and it stopped. ABS fuse is currently in. Also, if you coast the vehicle after the pedal vibrates a steady clicking comes from the front passenger wheel well.
3. The thermostat in the gauge cluster reads fully hot after 2 minutes of the car running.
4. I need a 50,000 mile check-up done
5. The car needs new transmission fluid. Synthetic is preferable.
6. Upon coming to a stop from 20mph - 0mph, the brakes squeak slightly.
7. When backing out of a parking space and turning the wheel LEFT, occasionally a loud scraping noise is heard.
8. When I first start the car and begin to go forward, if I turn the wheel LEFT, there is a very faint "thud" that comes from the front of the car, It can be felt in the steering.
9. There is slight play in the steering wheel. I had steering rack bushings replaced a month or two ago. The steering rack itself, I was told, didn't need to be replaced.
10. When I pump gas into my car, it does not matter how full the tank is, the pump shuts off like the tank is full repeatedly. A few times, I had only put 5 gallons of gas into the car (the tank size is 15) and it clicked off and spilled gas everywhere from underneath the rear fender. I went to check the fuel level in the car and it was only 1/3 full. The car has had a new fuel pump and seal installed, I don't know if that has anything to do with the problem.
[/b]Okay, please someone give me SERIOUS estimates on how much you think all this crap will cost and what maybe might not be totally nessecary because it's so expensive. I realize it's hard to know exactly how much all this will cost becasue you don't know exactly what's wrong but.. based on your experience what do you think?
RE: Everyone, read this please! I want REAL opinions!
Jesus...How old is it?? It only has 50k miles and all those problems? If you take it to a Ford dealer, you will obviously get your *** hammered by labor costs.
Yeah the car was beaten the crap out of for 45,000 of those miles. I already got a new motor put in.. because it threw a rod bearing. I just want opinions.. labor is 90 an hour there.
man you are talking alot of work. The average dealership charges around $90 an hour for labor. You can count on them most likely keeping your car overnight so Thats about 2 days work at the minimum for 90 dollars and hour. It's hard to guess because the noises could be nothing major or something huge. So i would have to guess ur hovering in the 3 to 4 thousand dollar range if not more. To give you an idea i had my timing chain assembly done at a ford dealer. It cost me 1200 and it was only there for like a 4 hours if i remember correctly. Sounds like its time to sell the stang if you don't owe any money on it. Take the money you get and use it to put a downpayment on another mustang. I am completely guessing on the price maybe someone here who might work for ford or is a mechanic can give you a better estimate. but good luck anyways.
ORIGINAL: Mustanggt9589
every dealer is diffrent with "book hrs" and their labor charges. but i would guess you will bent over for something close if not exceeding $2k. with all those problems it is kind of difficult to guesstimate. as far as the gas issue. i had that issue in my ranger and cougar. do you put the nozzle all the way in? or do you leave it out a bit? i know on some fords and even other vehicles (both my gti's) the pumps would shut off after a few seconds with the nozzle fully in there. but the tank would be empty. just gotta trick the pump lol
The gas tank issue sounds weird, but my guess would be that the hose leading down to the tank might be kinked or choked off at some point before it goes into the tank.
Most of the work is going to be troubleshooting it. You can at least count on a minimum of about 8 hours worth of work. I would insist that their best troubleshooter work on this particular job.
ORIGINAL: ChucksBullitt
I tried every single configuration possible. I even pulled out the nozzle so far I was watching the gas pour in. Doens't matter, all that does is make it overflow.
hmm..well you can take care of the transmssion fluid and the brakes yourself.
for the 50k check up, just run some fuel system cleaner, new plugs, new airfilter, new fuel filter, and clean the engine bay up a bit.
Thats about 600 plus dollarsright there.
90 dollars an hour is crazy! The VW dealer i use to work for had those labor rates.
The spark plugs, fuel filter, and air filter are 3,000 miles old. I ran fuel system cleaner it in yesterday. How do you change the transmission fluid???? I must know!!
