Supercharger >?<
Supercharger >?<
I have the 2v 4.6, i did the p.i swap and have most of the bolt ons, im thinking of getting a vortech for it, will i have to upgrade anything such as the injectors or fuel pump or is it simply bolt on and tune?
RE: Supercharger >?<
ORIGINAL: 9BlackOnBlack8
Im looking at this one
http://store.summitracing.com/partde...p;autoview=sku
If I decide to get this it will be my last upgrade for awhile so do you know what size injectors I would need?
probably 36-42lbs and you will be fine. also you can get the p1-sc complete kit for 4400 that includes injectors, fuel pump 3 core i/c. or the vortech v-2 mongoose kit for 3900 but no i/c.
i would recommend getting a i/c just for the fact that it cools the air and increase the hp by 40+ depending on type of setup but if you are going to get a twin screw s/c defitnetly get a i/c but for centri you can run 9-10psi w/o i/c. its all up to what you want to spend and what your goals are i guess.
o and dont buy that kit for that much not worth it. about 300 for injectors give or take and plus dynotuning since it does not come with a chip or programmer. if your going to spend that much i say get the kenne bell its shipped to your door for $5120. and it comes complete even their tune is pretty good for beginners at least.
