good springs
good springs
Well I think my springs are shot,I took the car to a local shop and anytime the car goes over big bump, momentum changes(slowing down, speeding up, parking and having to go back and forth to get in a spot) the car will make a sort of "thunking" noise, and they said they believe it is the shock. They said it could possibly be a drivetrain problem but they said everything is tight that in the body and suspension that could be causing the sound. Back to the topic though, I guess I'm getting new front springs, possibly back if they aren't too expensive. What is a good set of springs that aren't too costly, but I would like good quality if I am going to get performance springs anyways.
any suggestions would be nice, thanks!
RE: good springs
i have the roush blue ones , when you slam the gas the springs take it nicely along with how awesome it takes turns ,the downfall here in buffalo we have potholes and bumps i had friends heads hit the ceiling and almost bite their tongue off ...but it does keeep passengers out not sure about the price though
RE: good springs
ORIGINAL: BraMas
Eibach,H&R,Vogland,FRPP, all have good springs
Is your noise coming when you turn your wheel and back up?
Thanks guys
RE: good springs
ORIGINAL: BraMas
Sounds like its coming from front left(drivers side), but i cant see anything rubbing against anything. WTF. a lil help?
RE: good springs
ORIGINAL: sdtraviesosd
Mine does this! Just started doing it too. Recent work, new brakes, rotors, LT install so steering linkage disconnected K membered dropped. basically whole front suspension.
ORIGINAL: BraMas
