Idiot light on
RE: Idiot light on
ORIGINAL: sk8erdudex
Its saying you are low on radiator fluid just check the radiator. I've also seen this with low headlight fluid you might want to check that out as well. lol jk
RE: Idiot light on
ORIGINAL: jdaniel
Because if you knew anything about your car you would know that you have a plastic crossover on the intake manifold and Ford had a recall on them because they kept cracking. The recall replaced the cracked ones with aluminum crossovers. Your car is a specality so if it is cracked I bet they wont fix it unless Saleen authorizes it at an authorized dealer.
my car is not a recall car the only recall for the Sa-15 is an electrical problem and i had that fixed already. if YOU knew anything about MY car you would know that.
RE: Idiot light on
ORIGINAL: David_K
ORIGINAL: jdaniel
I did know that (are you illiterate?) but why would I keep up with a car that a bolt on GT roasted? LOL
RE: Idiot light on
ORIGINAL: David_K
dood for the last time you beat a s/c 6-cylinder
Ok... how about this... come to 1431 or Vans and I will use my buddys STOCK convertible and smoke your ***. How about that? But this time I WILL video tape it and I WILL post it all over the forums in Texas to show EVERYONE how damn slow that car is!!!
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
