Idiot light on
I got an idiot light on my dash and do not have the manual for my car. its on the far right side and it almost looks like a battery with an "X" on it.
RE: Idiot light on
Its saying you are low on radiator fluid just check the radiator. I've also seen this with low headlight fluid you might want to check that out as well. lol jk
RE: Idiot light on
Gracias
RE: Idiot light on
If that light keeps coming on you might have yourself a cracked intake manifold, but lets pray that's not it....
RE: Idiot light on
Blinker fluid..... hehehe. nice!
RE: Idiot light on
why would i have a cracked intake manifold? my car has 27000 miles on it
RE: Idiot light on
ORIGINAL: David_K why would i have a cracked intake manifold? my car has 27000 miles on it |
RE: Idiot light on
Because if you knew anything about your car you would know that you have a plastic crossover on the intake manifold and Ford had a recall on them because they kept cracking. The recall replaced the cracked ones with aluminum crossovers. Your car is a specality so if it is cracked I bet they wont fix it unless Saleen authorizes it at an authorized dealer.
RE: Idiot light on
ORIGINAL: jdaniel Because if you knew anything about your car you would know that you have a plastic crossover on the intake manifold and Ford had a recall on them because they kept cracking. The recall replaced the cracked ones with aluminum crossovers. Your car is a specality so if it is cracked I bet they wont fix it unless Saleen authorizes it at an authorized dealer. |
RE: Idiot light on
what years does that recall cover?
