Need help please
Need help please
Can someone give me an Idea what is going on. I have an 03 GT, It ran fine in the morning then in the afternoon it started fine and when I got a block down the road when I went to give it gas it wanted to die out. Luckly I was able to get it home. I was able to start it again and it was idleing terrible and would die out as soon as I put it in gear. I am unable to drive it because of this. Now it is having trouble starting at all and when it does it idles extremely rough. Does anybody have any idea as what might cause this? Could it be the I.A.C. Valve? Or could it be the dreaded and expensive fuel pump? And advice would be great.
Thanks
Thanks
Location: Where gunshots are more common than birds chirping
RE: Need help please
Injector Pressure Sensor could be bad as well.
Bleed the pressure from the fuel rails using the schrader valve. If when you start the car is runs ok for a second, its probably that.
