Speed limiter in a 98 gt?
Old 05-11-2005, 03:32 AM
wildazme
wildazme's Avatar
Default Speed limiter in a 98 gt?
Just wondering whats the speed limiter set at on a 98 mustang gt auto. How fast can i go before the fuel cuts off?
wildazme is offline
Old 05-11-2005, 03:38 AM
Guest
Guest
Posts: n/a
Default RE: Speed limiter in a 98 gt?
You're getting the rev limiter and speed limiter mixed up.
Most likely you won't ever hit the speed limiter unless you have a highly modded Mustang as most stock cars aren't aerodynamic enough to pull all the way through the speedometer like you see on some videos around here.
The Rev Limiter is when the fuel cuts out, keeps you from overreving your engine causing damage to accessories and keeping valve float out of the picture.
Old 05-11-2005, 05:17 AM
devinsteen
devinsteen's Avatar
Well, mine is set at 120...[:@] Many people on here claim their 98's are set much higher, but I don't know....all I know is that my 98 is limited to 120.....which sucks...cause it could do 140 I think...[:-]
devinsteen is offline
Old 05-11-2005, 11:17 AM
099gt
099gt's Avatar
i had a 96gt auto and went 150 i didn thtink they had fuel shut offs
099gt is offline
Old 05-11-2005, 11:40 AM
BCisme
BCisme's Avatar
ORIGINAL: devinsteen
devin, i've told you a bazillion times, it's because of the gears. 3,73 gears cause your rev limiter to kick in @ 120, or 4000 rpm's in 5th gear. with stock gears, 4000 rpm's in 5th gear comes @ 136 mph.
136 mph on a stock 96-98 GT.
BCisme is offline
Old 05-11-2005, 02:31 PM
devinsteen
devinsteen's Avatar
ORIGINAL: BCisme
LOL, I know, but the thing is that when I had my stock gears it did the same thing. At 120 it just cut me off with plenty of room to go. The 120 at 4000 rpm's with stock gearing sound about right from what I remember. But I'm telling you man, it would cut me off as soon as I hit 120 and still does the same thing with my new gears.[sm=dontgetit.gif]
Old 10-18-2021, 09:03 AM
Wayne Peyton
Wayne Peyton's Avatar
Default Speed limiter on 98 gt auto
.....hey bro...I have 98 gt.and it shuts off at 120 mph every time...so yes you do know what your talking about ..the other guy.obviously has not ran into this issue b4...but now you know there are other gt stangs.wirh the speed limited to 120.
Wayne Peyton is offline
firehorse02
11-16-2015 11:28 AM
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
BeatnikFink
10-01-2015 08:00 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: Speed limiter in a 98 gt?
