Lower intake with aluminum crossover
RE: Lower intake with aluminum crossover
What's wrong with a partially used one?? It's not like they're going to crack or anything... As long as the gaskets are in tact, then it should be fine.. Clean it up, throw it on, and drive on..
JT
JT
A used one will work, I just don't want the part under the crossover to be broken like the one I just took off my car. Part of mine wasbroken off under the crossover. There is a trenchon both side underneath the crossover where 2 small gaskets fit, part ofmy trench was broken and can't be fixed. So a partially used one will work, I'm just cautious about using one.
Thanks for the info.....
Luke9222
10-22-2015 11:55 PM
