Caliper help
Caliper help
ok so i need new brake pads badly.....like its almost donw to bare caliper and no pad. So my pads came in and i decided i was going to do the whole thing myself being that it is extremely unsafe to drive my car right now. So i took the front right wheel off. I then figured out that i would need a 12mm socket or wrench to remove the first bolt. After cursing and endless effort the bolt refused to give. Now I need suggestions on what I should do, because when i brake I can hear the metal grinding.
RE: Caliper help
I had the same problem with the Caliper mounting bracket on my Driver's side... I used Breaker bars, air tools, and heat and still wouldn't come off.. Thankfully, that rotor wasn't too worn, as it was replaced last year due to a caliper blow out...
Heat is probably your best bet..
Did you already get the Caliper out of the mounting bracket?? It's a pain sometimes w/ the Floating calipers.. Too many components..
JT
95 Eagle Talon TSi AWD - 12.7 @ 103mph (R.I.P.)
00 Mustang GT - Too Slow to Race, so far....
JT
mungodrums
09-29-2015 09:18 PM
maestro1024
09-21-2015 02:40 PM
inyadreems
08-21-2015 09:10 AM
