whats the best cai?
Old 05-11-2005, 09:14 PM
normbo03
normbo03's Avatar
Default whats the best cai?
whats the best cai?
normbo03 is offline
Old 05-11-2005, 09:27 PM
sk8erdudex
sk8erdudex's Avatar
Default RE: whats the best cai?
I have BBK and I like it alot
sk8erdudex is offline
Old 05-11-2005, 09:30 PM
Jimmz
Jimmz's Avatar
All CAI's are the same, A metal tube and a filter etc, heck you could even make one. Desencharger is supposed to be the best and it's supposed to give you the most power gains. I'm not sure why tho, but I know that it is also the most expensive...
Jimmz is offline
2k1gt
2k1gt's Avatar
Densecharger(www.demolet.com) or K&N.
And No Jimmz, it is not the most expensive in the least bit. Even the K&N cost more...
2k1gt is offline
Old 05-11-2005, 09:51 PM
66_mustang_04
66_mustang_04's Avatar
there all the same
66_mustang_04 is offline
Old 05-12-2005, 12:26 AM
rawkuspaul
rawkuspaul's Avatar
JLT CAI
http://www.jlttruecoldair.com
rawkuspaul is offline
Old 05-12-2005, 12:33 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
They are not all the same. Chrome is all show and hardly any go. The metal heats up and soaks through... heating the air that goes into your intake. Plastic doesnt absorb any heat nor does it heat to the temps that metal does. So they're not all the same. Get a JLT or Tunableinduction intake and call it a day.
jdaniel is offline
Old 05-12-2005, 12:40 AM
66_mustang_04
there all the same...i am the believer in that air does not stay in the tube long enough to get hot so it doesnt matter. Anyway its not going to make a night and day difference.
Old 05-12-2005, 12:49 AM
NoisyPony
NoisyPony's Avatar
I put the densecharger on my 04' GT and can say the quality and fit is very good, Don't know if it is any better than others because it is the only one I have used though.
I bought it because the air filter sits in the right front fender, cool air and not much induction noise in the cabin except under hard acceleration. It is heavy plastic pipe with a 1/4" thick wall so not much heat can get in, don't know how much of a difference that makes though? It is difenately pricey for what you get but, I am happy with it.
NoisyPony is offline
Old 05-12-2005, 01:01 AM
Blue70
Blue70's Avatar
ORIGINAL: 66_mustang_04
I think it's a bit more of a difference than you think.
Here is some actual physical evidence to change your mind...
LT1's have a coolant hose running through the throttle body, air stays in the throttle body a lot less time than it stays in a CAI.
Just by bypassing the TB the car dynoed 6 HP more and 7 ft lbs more.
Just think if it spent the length of a heat soaked CAI tube.
Here's the dyno graph and testing data.
Here, the dyno shows a 6.3 horsepower and 7.1 ft/lbs torque difference between having coolant run through the throttle body and bypassing it, with an average gain of 5.6 horsepower and 6.8 ft/lbs torque. I made the first test after driving the car for approximately 15 minutes. I monitored Coolant Temp and Intake Air Temp while making the run. At the beginning of the baseline run, the coolant was at 178F, intake air was at 80F, and the throttle body itself had a surface temperature of 102F. After bypassing, I again brought the car to temperature and repeated the test. This time, the coolant was at 180F, intake air was 80F and the throttle body was at 82F. To make sure the runs were accurate, I set the cruise on the dyno to 70mph in 6th and let the car run for about 6 minutes. After this time, the throttle body had reached 100F. I let the car cool to 185F coolant temp, and 88F intake air temp. Running the car again with these elevated heat readings yielded another .2 horsepower and -.2 ft/lbs torque compared to before heat soaking the engine.
Blue70 is offline
Jb145700
08-21-2022 06:37 AM
baddog671
07-26-2016 01:20 PM
mapitts
05-15-2016 02:57 AM
junior04
09-28-2015 10:53 AM
firecoyote
09-27-2015 02:37 PM
Quick Reply: whats the best cai?
