clutch size
RE: clutch size
Dont know why they would change it just in those years???
Flywheels
Whenever you install a new clutch it's a good idea to replace the flywheel to reduce clutch chatter and increase durability. Billet steel flywheels add extra safety and prevent flywheel failure from excessive horsepower, heat, and high RPM.
ADD TO CART
Description Price
Discontinued
1996-1999 Cobra & 1999 GT Nodular Iron Flywheel
$125.00
161-6375-G46
1996-1999 Cobra & 1999 GT Billet Steel Flywheel
$225.00
161-6375R00
1996-2002 Cobra Aluminum 8 bolt Flywheel
$350.00
161-6375-D46
1996-1998 4.6L GT Nodular Iron Flywheel
$125.00
161-6375-F46
1996-1998 4.6L GT Billet Steel Flywheel
$225.00
161-6375B302
1981-1995 5.0L Cast Iron Flywheel
$99.95
161-6375C302
1981-1995 5.0L Billet Steel Flywheel
$220.00
161-6375A302
351 Billet Steel Flywheel
$220.00
Steeda.com
Maybe this will help??
Flywheels
ADD TO CART
Description Price
Discontinued
$125.00
161-6375-G46
$225.00
161-6375R00
$350.00
161-6375-D46
$125.00
161-6375-F46
$225.00
161-6375B302
$99.95
161-6375C302
$220.00
161-6375A302
$220.00
Steeda.com
RE: clutch size
My bad, I forgot to add that only in the Windsor models they had the 8 bolt crank, and the Romeo was 6 bolt. So some will have the 8 and some will have the 6, depending if it's a Romeo or Windsor engine.
RE: clutch size
thnx for the replies, a dealer around here says hes got a 10.5 in clutch, 10 spline for the 3650, the cobra is 11 in, 10 spline, for only a few bux more, do you all think the 11 in would fit being they had the same tranny, block and bellhousing for that year? i will be getting a new flywheel, dont really need a performance clutch, but i figure if the cobra clutch would fit it is prlly better neway
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
