Steeda Timing Adjuster?
When should you consider getting a Steeda Timing Adjuster, if at all? I just started modding and so far have:
SLP Catted-X
SLP LM II’s
Steeda Pulleys
FRPP 4.10’s
K&N FIPK
Eibach pro-Kit lowering springs
I’m thinking that I prolly don’t need one for a while. Have my eye on a new TB & plenum next, followed by hand-held tuner, etc.
SLP Catted-X
SLP LM II’s
Steeda Pulleys
FRPP 4.10’s
K&N FIPK
RE: Steeda Timing Adjuster?
whats up devil dog. get the predator tuner for $399 new and you can advance the timing or anything else you want to adjust its got a good tune out of the box got to run high octane though. worth the money all the way
Whats the max timing you can turn it up to. I heard 12 degress is the max. shed some light on this firemedix. I want 14 degrees. It would be a bunch of crap to have to buy both.
ORIGINAL: maddash
So if I plan on getting a tuner (which is one of the next mods on this list), I won’t need timing adjuster?
no you want need a ta the predator which i have and personally believe is better because it gives you so many user adjustable options it remaps the timing and fuel curves plus many other things to list go to www.diablosport.com and check it out, but some will disagree and like superchips just compare before you buy for your needs. superchips advertises i believe 16 or 18 horse hp.dont no if thats rwhp or not.the pred advertises 15-20rwhp.these are probably high advertisments but the pred woke up my stock 04 gt with a vengence.i just got my current stang a month ago brand new that and a fipk was the first things i got for it. im going with pulleys,3.73(4.10 to much for the driving i do) x pipe(catted). then after warranty im unleashing on it.if you go with a programmer or ta just dont forget to run premium please.semper fi
ORIGINAL: maddash
Semper Fi!
Since were on the topic of the Steeda Timing Adjuster, perhaps someone could be kind enough to send me to a link or PM me instructions on how to install and adjust it? I have had the T/A and Underdrive Pulleys sitting here in my office for nearly a month now, still no sign of when I will be able to install it.
I'd really hate to spend all the money to have the dealer toss it in...
if you dont have an impact wrench and a puller just find someone to install them for you about 75-90 dollar range.to install timing adjuster i believe you can go to google and type in steeda timing adjuster install and go searching or contact steeda
