running rich....help
im having the same exact problem with my car! i just installed lt headers and a high flow catted midpipe and i had a catback already and my car was running like ok it could have used a tune cause it was running a little rich. But i drove to my gf college and on the way back it was running like ****. When i would stop it was idling fine but it was shaking like crazy. So idk what the hell to do. I think ill clean the egr first and check for vacums leaks. Oh and its running rich too you can smell it. Anyone else have any sugestions?
ok my car is runnin rich and its gettin way worse...i have the air/fuel ratio gauge and its completely over in the rich side at times and then sumtimes a lil or none at all and idk wat to do...i have papers that say its been dyno tuned and blah but i also have a handheld tuner and it only adjusts wot fuel and its runnin rich on idle and it sputters a little and it has a slight hesitation and more power at times then at other times...ne help is needed and welcome and also how bad can this hurt my car thnx
second, what numbers is the gauge showing? The car should run pretty rich being an FI car. Being rich at idle isn't necessarily a bad thing either, unless its so rich its causing the stumble problem.
Sounds like to me you need to hit a dyno with a wideband a/f ratio meter. Playing with the handheld and your in car a/f meter is a sure fire way to blow up an engine.
