5.4 dohc build
Yeah, you could but you probablly want to put 03-04 cobra heads on it from what i understand they flow better.
Also your compression ratio will change when you change the heads, i think it goes way up.
Off they top of my head I cant say I know you probablly want to look at some flow charts for both.
Also if you want to use a stock intake manifold off of a cobra or mach 1 you are going to need some adapter plates due to to difference in deck height between the 4.6 and the 5.4
The 03/04 heads dont outflow the 99/01 heads by much if at all, they do have a little bit better springs, but they are essentially identical, B heads from my research actually flow the most with imrc deletes and port work, but between all of the above the difference is nominal
