2v & 4v
I think it can be done for less, this is just my opinion. I've seen complete 4v engines with spun bearings going for under $500. I think if you're patient and shop around, you can do this swap for under $1000 if you do the swap yourself. A head install isn't as bad as most people say. Just take your time and follow the instructions in whatever manual you use or get someone that knows what they're doing to help you.
Yes the 4v heads will bolt right up to our stock 2v shortblocks. GT pistons (99-04) are 17cc dished and 4v (99-01) ate 10cc. There is no clearance problems. If you know what your doing and what to buy it will cost under $1500 if you don't and your asking this question you will be looking at alot more.
ok, my retarded self is learning.. are the 05-08 heads compatible with our short blocks?? i know they are 3v but just for my fyi
