Any turboed 4.6 with a stock block making near 400rwhp will blow no matter how outstanding the tune is. The boost hit created by the turbo is too big for the stock rods.
The kits that i have seen by hpperformance make alot more than 410 rwhp on 8lbs of boost on a stock 99-04 gt on pump gas. Centri on the other are as low as 370 - 390. I have full boltons, good compression, full exhaust and cams so i would definately make even more power. Nitrous sounds good, but i rather have constant boost.
good luck on recieving your turbo kit from hp.. it will take around 6-7 months and i was rushin them. they say like two or three but add atleast 5 to that. also good luck installing it, there is alot of custom fab work you have to do.
also, i have never seen a 55lb P-51. i would say mine is in the 30's range or less.
i made 440rwhp on 10lbs with my old vortech centri and i only had full bolt ons.
they make alot more than 410 cuz they lean the hell out of them probably to get all the power they can.
The TFS intake has a large runner and is excellent with a turbo/supercharger application. It will be better on the street than the P51 and for the price you can not beat it.
