Need some info...
Need some info...
Going to buy some Greg weld dragstar wheels for my 97 gt 15/8 rear 15/3.5 front questions are...
Anyone running these, whats your opinion.
Along with new lugnuts what else do I need? Offset washers etc.
What backspace would work best 4.5 or 5.5?
As far as tires I have 3.73 gears and Im running a 17 275 40 on the rear now. If I run a 15 275 60 or a 15 275 50 how much are these gonna drop my gear ratio?
Thanks.
Thanks.
A 275/60-15 is essentially a 28" tire, which is too much for what you need. Stick with a 26" diameter tire, like the 275/50-15. Stock tires are 25.8" in diameter, so these will be the same size.
You will want 5.5" BS for an 8" wheel.
Also, for the front skinnies, you'll need a 7/16" spacer to clear the calipers.
7angofragger
12-19-2009 12:21 PM
