Rev limiter question
#21
RE: Rev limiter question
Am I reading that wrong or did you gain 21HP and lose 2 lbs/ft of torque? odd, but radical cams pull all the way through the power band, which stock cams will not. Needless to say, it is only inefficient, pointless, and dangerous for your stock cam'd/headed car to rev high.
#23
ORIGINAL: DILO2001GT
so what should i set my rev limiter back to? its at 6600 right now and its an automatic. shoudl it be at 5700 or 6100? thanks
#24
ORIGINAL: 98UAGT
I would not set the rev limter over 6100 RPM. And like everyone is saying, you don't even need to rev that high.
You only need to rev high enough that when you shift to the next gear you are still in a good powerband. Other than that, there is no reason to rev the crap outta a stock cam'd N/A GT.
treesloth
09-28-2015 07:03 AM
