What slicks to run on 1/8 mile?
If it was only so easy......are you breaking traction with your current set up? If you are spraying and you have slicks you are likely to break something in the rear end. Or if you are running a supercharger or something with some significant power you probably will break it. If you want 31 spline axles you need a 31 spline carrier. It adds up quick. I say go break the stock rear end and give yourself a reason to upgrade. LOL
Edit: I see you are running a procharger in your sig i missed that. You could upgrade your control arms springs and shocks that will help your weight transfer. Slicks will help but they are not the fix all to your problem.
This tire should work well.
http://www.mickeythompsontires.com/s...?item=ETStreet
26x11.50-15 That is if you are wanting a track only tire (IMO)
I would rather just get a slick, but needed to know ahead of time if 31 splines were a most. I want to launch at a high rpm so I am in boost already. Right now I am having traction issues and wanted some advise to fix it. I thought slicks were the first thing to go with, or should I just do it all and say the hell with it.
bryan616fl
01-25-2019 09:07 PM
cardsrus1
19
09-15-2015 08:37 AM
