what do i need to be at 300 HP
If i had 3,000 and wanted only performance.
LT Headers
Mid pipe
CAI ($89 on AM)
TB/plenum ( $299 on LMR)
UDP (not really worth it but every bit helps)
STS
thats without going into the motor and probably wont get you 300 hp.
you could do Cams but you should do Heads too while youre in the motor, er thats what i would do. if you can do stuff like that then get heads and cams. but install would be killer.
or you could do a supercharger but i just said the NA route
LT Headers
Mid pipe
CAI ($89 on AM)
STS
i dont think that would get him 300Whp but if hes looking for crank it could happen.
i suggest a used s/c also, will get you a good ways above your goal and will be safe if you run conservitatve boost.\
sexy said the n/a route... i however would never take out a loan for just performance...
