help bushings
You have a creaking in the steering correct? Ford came out with a TSB for this.. Its basically replacing that metal tube that the rack bolts run thru with a shorter one (or maybe it was longer) and replacing the bushings with new ones. The bushings may be the noise, but the stock tube is also a cause and should be replaced with the updated part
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-16-2015 07:53 PM
