Can i get these cam gears aftermarket or do i need stock windor ones?
You don't need to buy cam gears. You have bolt on cam gears from the factory, the guy with the 2000 was the one that needed to buy them when he bought the aftermarket cams, as Windsor engines came with pressed on gears.
Just reuse your cam gears with the aftermarket cams.
I'd suggest going with adjustables anyway, but if you just want to get the cams in, you can use your stock gears.
Adjustables are not needed at all. You can degree cams using the stock Ford cam gears (grind the keyway), and it's a much safer prospect than most of the POS aftermarket gears available.
