Coolant leakage
#21
Ok, I took some pictures with the intake off. I'm not sure if these are the PI gaskets or the stock ones.
^I think thats the bellhousing where its leaking from.
You may not be able to see, but the water pump hose is not leaking. All the brown stuff in the jackets is corrosion from sitting for 4 years. Freeze plugs are fine.
huh, thats what my car looked like for the past three days,I am having the same problem with coolant leaking. I have a bad misfire in it too. I just cleaned all mounting surfaces really good, put new intake gaskets on and i haven't seen a leak yet, but is only been 24hrs.
#22
If your gaskets look like mine, then they are PI gaskets. I ordered gaskets and installed everything today. The car runs with no coolant leaks and idles a lot smoother.
Now only if I could get my fans to work... and the vapor hose... Then my car would be drivable.
Thanks for all the help.
