track time question
#23
1st off... no offence.
2nd... yea man that car should go alot faster
3rd... bone stock, i went 2.1 60s, and 13.7 at 102... i honestly dont know where i was shifting but it wasnt 6k, and 3rd, i threw out of early and hit 4th, made a good differance.
4th, idk what kind of tire is on that car, when u grab 2nd it ought to kick out to the side some... if not, shift faster.
come out of the hole around 2k, use the clutch for traction
bottom line... that car should be capable of 13.5s at about 102-103
however take it for what its worth, in my stock new edge(now with suspension and 3.73s) i had(and have) fun finding small bolt on gt's and racing them from a stop.
#24
i can understand that...but were you granny shifting?, speed shifting?, powershifting?, was it in the winter? and as far as the shift points go, thats just something i will have to try out next time
#25
I was running 14.1 in the 1/4. Im in an automatic. You need new tires. With 60' like that you problem is traction... you should be in the mid 13's. What part of texas are you from im in houston where baytown is at sea level. It makes a difference.
#27
it was spring time. i was not flat shifting at all, no WOT shifts, but yea man i shifted it like i didnt care if something broke...and something did... 3rd gear syncro... then i ran the car w. the bad syncro, literally slaming it into 3rd and listening to it cry some... ran the same times...
#28
well you have ***** the size of an elephants , ill def try to drive a lil harder but this car is my daily, and im pretty sure prositiutes make more money than i do so i cant really afford anything to break, but i know you gotta pay to play
#29
Ha I feel ya on that one. Work is SOOO SLOW right now Im making literally no money. I just broke the 3-4 shiftfork in my Cobra about 3 weeks ago, 25$ and some ATF later Im back on the road... drive it like you stole it man.. **** happens.
