Fuel System ideas
Fuel System ideas
Can someone point me in the right direction as far as upgrading my fuel system? Obviously I will get 30 or 42lb injectors, a SVT focus fuel pump but then i am stuck after that. Should i get bigger fuel rails? I was looking at aeromotive fuel rails but i don't see a whole bunch of mustangs with aeromotive stuff, why? As far as the car it will be a street car with around 330whp and on nitrous i figure i will be in the 450-475 whp range which will put me over 500ft-tq. so basically i just want to have a safe fuel system that would hold that power and be safe enough for a little more power. thanks.
Location: Where gunshots are more common than birds chirping
SVT Focus pump w/ 40amp Kenne Bell BAP, but wait, isn't your car a return style system still?
You could do an A1000 inline system with a better regulator and bigger rails and injectors.
96-98 have two high pressure fuel lines. I'm almost positive that one is delivery and the other is return, because 99-up went returnless and they have one high pressure fuel line running to the rail. I may be wrong but check to make sure before you buy anything.
I think you are right... that is how i remember the fuel rails when i took apart the 01 spare motor i have. I'm not looking to buy right now i just like to know what i need before hand so i can research everything and get what best suits my car.
