Mid to Low 12's, is it possible??
#21
my kit is hooked up running an on/off switch(toggle) then goes thru a window switch and a WOT switch... you have the right idea
and your looking at an 11 sec car easy if u do all that and spray it
hell with 4.10s, exhaust, a tire, suspension, tune and a 100 shot im aiming for low 12s/high 11s....
#23
I'd look into a built rearend, good suspension, flsfc, and slicks, a good clutch (if you have a 5 speed) You should reach your goal without N2O and exceed it with it. I went 12'0 on a STOCK motor with a 100 shot (with the things I mentioned), with mods now (heads, cams, exhaust, etc) I'm running mid 12's on the motor and 11's @ 120mph+ on only a 100 shot.
jwog666
12-27-2021 08:09 PM
