Any major differences in CC plates
It depends I will usually run -3.2 or -2.8 on the track (depends on how it feels).
When on the streets I just use an alignment within factory spec about ~ -1.1 or -1.2.
I keep the caster set close to +4.4 and don't usually mess with it.
One other comment, if you have any future intention or inclination toward coil-overs make sure you get a robust 4-bolt set.
I have seen the lesser stamped metal units seriously deformed by running them with coil-overs...
I actually need to get a new set. Sometime soon for that very reason. My drivers side one has begun to bend and I can hear the bearing starting to make some noise.
I had the old design before they started making them "stronger and better". But I heard somewhere that the newer ones give you a smaller range of adjustment than the older ones did. I may have to look at Griggs now.
I had an opportunity to compare the MM and Steeda plates side-by-side when I bought my plates.
It was obvious that the Steeda plates ($30 more) were a more robust product, however if I had been aware of the Griggs plates I would not have had a problem spending another $100.
treesloth
09-28-2015 07:03 AM
mungodrums
Suspension
09-24-2015 10:12 PM
