need help asap
need help asap
I need to remove my cam so i can get to the vavle seals on the first cylinder how do i go about doing this. I already have the valve cover off and the cam unbolted i just need to get the timing chain off. Its my DD so i wanna change the seals quickly.
How are you planning on changing the valve seals with the cylinder head still on the car?
It can be done, but you'll an air compressor and a spark plug hole fitting to hold the valves closed so you can remove the retainers and springs. Then even at that you might be able to remove the old seal with the valve in place?
i got it done. Theres a special tool for ohc's You dont have to take the cam off it uses the cam as like a pivot to compress the spring so you can take the keepers off. It was a piece of cake once we got the tool. And to keep the vavles up i found another trick. You put the cylinder down a little and putt nylon or any kind of like soft rope and pile it in there and than put the piston TDC and it holds the vavles up. It worked like a charm.
