Do I need a pullie puller?
Ive just received my underdrive pullies..they are Steeda.. i have a 2002 mustang gt..just wondering if i need a pullie puller to remove the other pullies?
thanks
thanks
You're going to need it to remove the crank pulley, the others you won't need one for. Just make sure you leave the belt on when you try and get the alternator bolt out, it's a royal PITA. All the others are simple to get off the car.
2010 Blue Ball Award Recipient
You'll need a crank pulley remover *different than a p/s pulley puller* and then you'll need a p/s pulley remover obviously, lol.
I've never taken an alternator pulley off before, so you'll have to listen to sinister on that one.
Because I don't know what pulleys an underdrive pulley kit include.
Judging by your tone, a kit does not include a new pulley for the p/s pump, so, he won't!
Assumptions suck huh :-(
The underdrive pulley kit from Steeda includes a new water pump pulley, an alternator pulley, and a crank shaft pulley, sometimes called a harmonic dampener.
Definitely rent it from Autozone or something like that. You buy it, then use it, and then return it and they give you a full refund. Be prepared to fight the alternator pulley though. I know I had a really hard time with it.
