Just mark the chain to the camshaft gear and at the crank gear. And just line it back up when you reinstall. Since your only taking one head off the other cylinder head chain will act like a crank holding tool and keep it in position.After all said and done hand crank the engine a few times just to make sure everything is good to be safe.
there not that bad. Iv'e had boths cylinder heads off before in about an 1 1/2. But i had air tools. Also a little trick grab a few rubber bands. I believe there is gonna be a few head bolts that will not come out all the way with the engine in. use the rubber bands to hold them up to prevent them from falling when you take the head off and potentionaly scrathing a cyl.
