missing 1000-1500rpm.
About a week ago I had a t-fitting that recirculates coolant from the intake back into the heater core line fail, dumping coolant everywhere. To make a long story short it now misses under load in the 1000-1500 range, then goes away anywhere above that. It also only misses once the throttle is opened to a certain point. Before i go with plugs and coils I want to know if this could have dirtied up anything through the intake? I have a hunch that it sucked in some coolant and fouled a plug or 8. Any ideas would be helpful.
The first thing you need to do is pull the COPs and make sure the plugs wells are dry--get the coolant out of the plug wells (stuff paper towels down in there, use a shop-vac with a thin tube taped on, compressed air, or whatever).
Chances are you'll find one (maybe #8) with coolant in the well...
Location: vids> http://vids.myspace.com/index.cfm?fusea
dude u read my mind, i took off my manifold and i cant get that hose back onto the mainiford right.. its getting into cyl 4 through the spark plug hole.. check ur coil and plug i bet they are wet.
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
