i just found out if I use a set of non PI Heads and just get them ported that dosent make my c/r go up is that true..is there any down side of that.
(if u port) PI - High comp, good for N/A or Nitrous, but you gotta be careful about boost
(if you port) NPI - Good for boost because it doesn't affect compression ratio
well like i said, you could just blend the combustion chamber to drop your c/r if you wanted to run a blower, i would say you should have it done anyways, just not a lot to help un shroud the intake valve to allow for better flow but keep your c/r high. either way its going to be higher than what you already have.
I saw a full bolt-on, cammed 2v at hi-tech motorsports that made 312hp with a stock pi intake and 304hp with the P-51. Not only did it lose low-mid end power, it also lost peak hp. I certainly wasn't impressed by the P-51.
A bud of mine (Camdup) had a similar setup and the same results. He went back to the PI intake and was happy
