Last Opinions/help needed. Car performance horrible
Alright this problem started after I filled up at a gas station about 4 months ago and has decreased a little since then but still persists.
Under acceleration the car will studder and struggle like it wants to go but won't.
Everyday the studder is more/less noticeable; it isn't consistent at all.
It also is more prevalent when the A/C is on, and it happens greater in every higher gear.
Whether these make a difference or not, this is what I have done to the car in the last 4 months: Change the fuel filter, air filter, brake fluid, coolant, cleaned the MAF/carb/IAC, and ran LUCAS fuel treatment thru a tank.
I also had a a shop plug it up and see if any codes were present but he said since I jumped someone's car and the battery cleared the codes or something? none will ever show.
But I'm stumped and I'm tired of my car performing like crap and to top it off someone just did a hit and run on me in the parking lot while I was in class. :/
Thanks for any help guys.
I had a simular problem, well actually it sounds exactly like my OLD problem. Sometime after it rained hard or after I washed my engine I would experience what your going through. I tried everything. After a day or so the problem would go away only to return when it raind or I cleaned my engine. After I blew my supercharger tube off (before the MAF)one day, I noticed there was rusty water marks inside the tube. I think that was my problem. I reinstalled the tubing and clamped it super tight and I haven't had the problem since. I'm not saying thats whats wrong with your car but I did check my MAF 2 times after the sputtering started and I thought it was OK.
