Just installed a Steeda TriAx shifter last night..............
I set the arm to the "short shifter" position instead of "comfortable position"...............in other words, lower. While the throws are indeed shorter, its alot harder to row now.
Does raising the position up make any significant kind of change???
Technically going with a shorter arm you are going to lose mechanical advantage and it will be harder to shift. It i just a lever and making it shorter will make it slightly harder to shift. I think in either position you will get used to it after a day or two.
Dont forget that the shifter loosens up a bit too in about a week or two making easier to shift and not so tight.
Really? I hope so.............its a bit notchy although even if it didnt loosen up Im sure I'd get used to it after awhile.
I'll tell you though............no more missing 3rd gear for me!!!!
i had mine lowest pos. then i changed it to the higher position i feel i get quicker shifts with it up a bit because if the leverage just changing it to the steeda makes the throw shorter from stock
