Engine mounts and drive by wire might give you trouble.
The block is the same so engine mounts shouldn't be an issue, assuming he uses the mounts from his old motor. The TB will have to be replaced with a standard TB.
logan has a little conversion kit, you would have to swap the computer to keep the vvt - which is one of the best parts of a 3v. The TB has to be changed out - logan has that adapter to hook up an older one. If your going to gut the car than using the newer computer and all may not be to bad, but I would think that trying to integrate that with the older stuff would be a nightmare. Most people get the adjustable cam gears and keep the 2v computer... in which case you might as well do a 4v
Never thought about the variable valve and such.
What would be the "easiest", best bang for the buck turn-key motor to buy for a New Edge? Wouldn't be looking for anything outrageous, but something with more pop than the 2V motor.
