What gear (rear end) do I have?
Jack up one tire if you have an open diff, or both tires if you have a working posi or locking differential. Rotate the tire one full revolution for posis and lockers and 2 full revolutions for open diffs. Carefully count the number of full revolutions the driveshaft makes. This is your gear ratio. In other words, if the drive shaft turns 3 ¾ turns, you probably have a 3.73 gear ratio. Turning the tire for twice the number of full revolutions and dividing the drive shaft revolutions by two will give you a more accurate reading.
Darn you're quick.
OK more info. 1996 Cobra 1FALP47V7TF141656
I just bought the car and it is georgous.
On the car, there is a Tremec TR3650-4 transmission, I'm trying to figure out the speed sensor I need as the speedomer is 4.6 time to fast.
Again, thanks a million
This forum is the best
